reçu aussi
Enhancements
Added support for Match audio content resolution feature when using a USB DAC
Added ability to clear HDMI 1.4 flag via factory reset
Added match Frame Rate (beta) enhancement
Added French parental control
Added security enhancement for 4K DRM playback
Known Issues
SHIELD TV will be removed from Google Home integration after SHIELD Experience 9.2 installation. Visit NVIDIA support to reconfigure.
Resolved Bugs
Fixed choppy video playback after FFWD/RWD operations
Fixed remote stops responding for 60 seconds after wake from sleep
Fixed SHIELD waking from lock screen without a button press
Fixed issue with large file transfer to NAS (operation not permitted error)
Fixed Google signing flow stuck in a loop
Fixed stutters in Bose and Sony headsets while connected to 2.4Ghz Wi-Fi
Fixed audio stutter in aptx supported headsets
Fixed AV sync issues when Dolby Processing is enabled
Fixed crash on volume change
Fixed Apple Music corruption during casting
Fixed Spotify empty playback when Match Audio Content resolution is enabled with Stereo Upmix
Fixed Google Assistant not starting after Google GMS update
Fixed full screen SHIELD Rewards notification issue
Fixed Wi-Fi log filling up storage
Fixed SHIELD drive filling up
Fixed no audio heard when headset is connected to controller and DAP is on
Fixed Geforce NOW crash after launch
Fixed video distortion on "RGB 8-bit Rec.709" display mode
Fixed USB HDD/Flash drive showing corrupted after hotplug
Fixed NAS folder info shows 0 B and not the actual capacity
Fixed mounted storages not listed after upgrade
Fixed occasional crashes in DRM apps
Fixed when Alexa SHIELD Skill cannot locate SHIELD TV device
