Modérateurs: Le CA de l’Association HCFR, Modération Forum Home-Cinéma • Utilisateurs parcourant ce forum: bauer, DR NO, nnay07, warrior1300 et 97 invités
Zidoo X20 / X20PRO (2xHDD bays, ESS 9038, Dual HDMI, etc...)
Message » 31 Déc 2019 14:15
bonjour a tous,
FW Beta disponible ici
http://forum.zidoo.tv/index.php?threads ... eta.65323/
Changelog
(From here, translation via Google Translate.)
System
1. Optimize the problem of the USB 3.0 port even if the device is lost
2. Fix the problem that DTS track music cannot be played
3. Fixed the issue that HIFI music will not play automatically next time
4. Optimize online playback
5. Increase the global press "Information" key to display the current HDMI output information
6. Optimized the problem of abnormal sound after DTS music playback is paused
7. Fix the problem of abnormal sound of Bluetooth device when HDMI output is set to source code output
File manager
1. Fix the problem that the same share name is displayed in NFS (for Usbshare multiple external hard disk cabinets, only one can be found)
2. Cancel the top navigation category and add the list rotation function
3. Added CD disc insertion tips
4. Optimize sorting function (save separately by path)
5. Added the function of pressing "Popup" to return to the top of the list
6. Fixed the problem that the played video does not prompt the watched icon
Poster wall
1. Optimize the display of the details interface and the movie video
2. Optimize segmented video scanning
3. Optimize scanning to solve the problem that stopping scanning during scanning may cause unmatched videos to not match properly when continuing scanning
4. Solve the problem that the child lock set is not displayed synchronously after the movie rating is initially set
5. Increase the HDR corner mark (scanned videos will not be displayed)
6. Optimize file name recognition
7. Optimize application stability
8. Optimize bracket processing for title recognition
9. Added trailer filter filtering, the word 'trailer' in the file name will no longer be scanned
10. Optimize the NFS mount method
11. Fix the problem that the background service causes the setup wizard language to be incorrect
12. Fixed the problem of disordered video in the folder video list interface
13. Fixed the problem that poster information cannot be obtained based on the file path
14. Fixed the problem that the total number of videos on the device does not change after moving the video out of the poster wall
15. Clear device and delete device will remove related video information from database
16. Fixed the issue that the poster does not refresh after modifying the rating of the child lock
17. Child lock setting interface adds function description and child lock reset function
18. Optimize the collection function
Music player
(requires removing folders and rescanning to get new features)
1. Optimize folder browsing function
2. Add CD playback function (requires external optical drive)
3. Optimize the sorting function
4. Optimize the calculation method of scanning progress
5. Optimize track identification for SACD and CUE albums
6. Improved the interface of obtaining track list, and solved the problem that the mobile phone cannot control the CUE / DSF track list of the temporary list
7. Modify the time display format of CUE to keep the same with SACD
8. Optimize focus control logic to solve the problem of focus flicker
9. Modify the recording method of the playlist to solve the problem that the last song in the random play mode will replay randomly
10. Added screen saver function in play details interface
11. Fixed an issue where the list interface displayed an error after the grid layout removed the list
12. Fixed the problem of getting albums when playing music from file manager
13. Fixed the problem that the lyrics could not be closed without playing the details interface
14. Fixed the problem that sometimes the detailed interface picture cannot be obtained
15. Added automatic full-screen playback switch
16. Added music file information display to the list
17. Solve the problem that search interface focus may be lost
Local player
1. The problem that the optimized bit rate is displayed incorrectly
2. Fix the problem that the movie name is displayed incorrectly
3. Add ZOOM function
4. Increase the video ratio
5. Fixed the issue that Polish subtitles are displayed in Portuguese
6. Optimized subtitle download function
7. Optimize the front panel USB icon display
8. Optimize the problem that DVD cannot select chapters
9. Optimize ASS subtitle display
Blu-ray navigation
1. Added the function of subtitle track list displayed by shortcut keys
2. Optimize subtitle download function
Quick settings
1. Add ignore EDID function
Mobile APP
(need to update mobile app v.1.5.3, IOS version please go to APP STORE to update)
1. Add audio offset setting in the setting interface
2. Folder browsing function has been added to the music device interface
3. Application interface adds sorting function
4. Fixed the problem that the same device is repeatedly added to the music device interface
5. Fixed the issue that the CUE / DSF track list cannot be obtained from the temporary list songs
6. Optimize the problem that the application interface icon is not displayed
7. Optimize poster wall interface display
8. Solve the problem that the file management is affected by the search bar, and it will return to the upper directory when rescanning SMB or NFS
9. File manager adds list refresh function
Qui dit BETA dit utilisation a vos risques et périls.
a bientot
OlivierQC
Contributeur HCFR 2018
Inscription Forum: 23 Avr 2003 14:01
Message » 08 Jan 2020 18:22
Deux petites questions : avec un X20, peut-on se connecter à son PC en réseau (par ex, comme avec une Freebox en UPnP) pour y accéder à ses vidéos et sa musique ? Si oui, est-ce que le X20 est compatible avec des architectures de Blu-ray qui ne sont pas compilées en ISO mais uniquement sous forme de dossiers classiques (BDMV + CERTIFICATE) ?
tenia54
Message » 08 Jan 2020 19:19
Oui il sait faire tout ça, lecture et écriture en réseau et lecture de dossier BDMV
Arakhine
Inscription Forum: 22 Jan 2007 0:58
Message » 25 Jan 2020 23:37
Bonjour a tous,
Ajout en page 1 du lien pour la derniere version du zidoo controller et du FW 2.3.10.
A bientot
OlivierQC
Message » 30 Jan 2020 18:21
Je viens de lire les 31 pages et il me reste quelques points à élucider qui sont les mêmes que pour le zappiti 4k
1-Quels sont les appli android que l'on peut réellement utilisé sur ce X20 pro ? aucune même en passant par aptoide TV?
2 -Puis je garder kodi pour conserver l'interface et faire plaisir à madame ?
3- Quand est il de la qualité de la sortie RCA / XLR ou coaxial ? un tweak peut il amélioré ça ? comme sur d'autre box ?
Merci d'avance
Hellboy42
Inscription Forum: 09 Déc 2014 15:06
Message » 31 Jan 2020 1:36
salut Hellboy42
je ne pourrai pas te repondre pour les apk android, j'en utilise pas sur mes zidoo.
tu a ZDMC disponible en page 1 de mon thread et qui est un fork de Kodi, mais je ne l'utilise pas non
plus, je lui prefere HT 2.0.
multimedia-materiels-lecteurs-et-box/zidoo-x20-x20pro-2xhdd-bays-ess-9038-dual-hdmi-etc-t30081565.html
pour les sortie RCA/XLR, ils m'ont envoyé ce modele mais je ne les utilisent pas, mais tu peux aller voir sur le forum zidoo
ici par exemple : http://forum.zidoo.tv/index.php?threads ... les.10277/
et il doit y en avoir d'autres sur le forum zidoo
si il te faut du RCA/XLR, regarde pour le UHD2000 qui a de meilleur composant et qui est plus complet sur la partie audiophile (130 Euros de plus environs) mais qui doit les valoir je pense, par contre c'est la partie software qui peche chez zidoo.
https://www.futeko.com/browse.php?cat=mp&sort=relevance
de plus Mirak sauf erreur va sortir un test de ce UHD2000 bientot sur ce forum.
multimedia-materiels-lecteurs-et-box/zidoo-uhd2000-4k-hifi-test-hcfr-post-1-t30095702.html?hilit=uhd2000
a bientot
OlivierQC
Message » 11 Mar 2020 19:51
Bonjour a tous,
Nouveau FW 2.3.17 disponible
http://apidl.zidoo.tv/X20_PRO/v2.3.17/Z ... ackage.zip
A bientot
OlivierQC
Message » 11 Mar 2020 23:03
Merci OlivierQC,
Attention deux petites précisions:
Ce firmware est une version beta et ne fonctionne qu'avec le X20 PRO.
Voici celui du X20: http://apidl.zidoo.tv/X20/v2.3.17/ZIDOO_X20_N_v2.3.17_202002241519_ota-package.zip
Arakhine
Message » 13 Juin 2020 2:31
Installation du dernier FW qui résoud le problème de « seamless branching ou similaire », et les 2 ou 3 films ISO qui me servaient de test fonctionnent à présent correctement.
C’est pour moi un gros progrès et était mon dernier point noir au sujet des zidoo, et il semble à présent résolu.
A bientot
OlivierQC
Message » 13 Juin 2020 12:07
Voici le lien pour télécharger le nouveau FW pour le x20 PRO
https://www.mcbluna.net/wp/zidoo/zidoo- ... e-v2-3-32/
A bientot
OlivierQC
Message » 22 Juin 2020 12:51
Concernant le Zidoo x20,
niveau son, le HDMI v1.4 suffit pour envoyer du atmos ou du dolby true hd?
Merci ;)
xsander
Inscription Forum: 31 Mar 2018 9:28
Message » 22 Juin 2020 12:58
olivierQC a écrit:Bonjour a tous,
Voila les dimension :
Packaging : 52cm x 39 x 17cm
Zidoo X20/X20PRO : 43 x 30.4x 7cm
A confirmer, la boite de l'appareil serait toute noir et argent/gris sur les tranches, pas de photos pour l'instant
A bientot
43cm de profondeur?
xsander
Message » 25 Juin 2020 22:33
Comme personne ne réponds...
43 cm de largeur
Arakhine
Message » 25 Juin 2020 23:42
xsander
Message » 25 Juin 2020 23:43
Tu en es content ?
xsander
cron
