44kilobucks c'est pas cher, c'est moins cher qu'une robe faite à la zoigne par Karl Lagerfeld.
L'oreille, on s'en fout autant que l'amortissement linéaire ou accéléré de la robe suivant les normes IFRS.Et la crème Prairie pour les rides,vous savez le rapport prix: résultats sur "Mamy Shampooing"?
Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: assise_sur_un_ampli, corail 86, douda, ericb56, HoberM, Hoian, Loug, marc33, marcplai, MIB91, Minorswing, nab75, pacpac69, pm57, renaudga, rolex, Taisetsu458 et 553 invités
Pas de limite pour vendre (et acheter) n'importe quoi
- maxitonic
- Inscription Forum: 26 Jan 2010 9:58
Tiens, Bybee s'est mit lui aussi à la fibre de carbone :
Et toujours du grand n'importe quoi :
"The “stuff” developed by Bybee contains “crystal-like” materials that are activated by electromagnetism and have the uncanny ability to affect the alignment of protons in specific proximal atoms. Based on this ‘old fashioned’ model of the atom, such an alignment results in the nucleus having the properties of a bar magnet. This in turn results in an “easier” (more stable) path for EMF and therefore a reduction of the deleterious effects of capacitive and inductive reactance as well as molecular noise. If the components of an unaligned nucleus, protons and neutrons, churn about producing continuously fluctuating magnetic poles, it is easy to conceive that an array of fixed-pole nuclei will provide a consistent and predictable path for the passage of charged particles, as well as exerting a profound influence on the behavior of electrons in the “orbit” of the nucleus. Or something like that. Jack Bybee was careful to point out that his description, on which this speculation is based, was only an hypothesis; what I’ve written is several times removed from that."
http://www.stereotimes.com/post/new-hei ... pleasures/
- coincarre
- Inscription Forum: 12 Sep 2011 20:36
toujours aussi marrant ce post
le génie humain n'a décidément pas de limite
lovely Gotlib & Franquin
Déjà plus de 220 recettes, astuces, conseils...
brugam - Contributeur HCFR & Modérateur Bla bla
faut traductionizer, c'est plus marrant :
"nétait qu'une hypothèse" ! ! ! le mec fabrique, vend cher et il ne sait même pas comment ça marche, alors il invente des hypothèses
Michel...
Les "trucs" développé par Bybee contient des matériaux "semblables à des cristaux" qui sont activés par électromagnétisme et ont la capacité étonnante à affecter l'alignement de protons dans les atomes proximales spécifiques. Sur la base de ce modèle «old fashioned» de l'atome, un tel résultats de l'alignement dans le noyau ayant les propriétés d'une barre aimantée. Cette entraîne à son tour un chemin «plus facile» (plus stable) pour les CEM et donc une réduction des effets délétères de capacitive et la réactance inductive ainsi que le bruit moléculaire. Si les composants d'un noyau non alignés, les protons et les neutrons, le taux de désabonnement de produire en continu fluctuant pôles magnétiques, il est facile de concevoir que toute une gamme de noyaux pôles fixe fournira un chemin cohérent et prévisible pour le passage de particules chargées, ainsi que exercer une profonde influence sur le comportement des électrons dans la "orbite" du noyau. Ou quelque chose comme ça. Jack Bybee a pris soin de souligner que sa description, sur lequel se fonde cette spéculation, n'était qu'un hypothèse; ce que je ai écrit est plusieurs fois retirés de cela.
Michel...
- MickeyCam
et voilà le charabia de son site, un tissus de conneries auquel lui-même ne comprend rien :
Michel...
Les Purificateurs Quantum de Jack Bybee ont été initialement développés pour des applications militaires, dont beaucoup sont encore très classés. Ces dispositifs étonnants ont été utilisé pendant des années par les amateurs de vidéo et audio compétents pour atteindre des niveaux de pureté du signal et la transparence inaccessible avant leur introduction.
Dans tout système de lecture, informations musical et visuel est transmis par des électrons circulant à travers conducteurs. Comme les électrons interagissent avec les matériaux conducteurs de câbles et de circuits, très bas niveau (quantique) bruits sont générés. Comme l'énergie de bruit quantique accumule dans le signal de multiplication, les détails de bas niveau se rapportant à l'ambiance, sonore, le timbre, la dynamique, la fidélité des couleurs et de la résolution de l'image est obscurci, voler la présentation de la vivacité et de la vie.
Purificateurs Bybee Quantum fonctionnent sur le plan mécanique quantique pour réguler le flux d'électrons qui composent le signal (imaginez un flux de régulation de la circulation autoroutière de mesure de la lumière). Le flux de courant dans le Purificateur Quantum est libre et idéal (pensez à la fluidité des flux de trafic sur une autoroute peu fréquentée). Pendant le transit à travers le Quantum Purificateur, l'énergie de bruit quantique est enlevé les électrons, la rationalisation de leur écoulement à travers des conducteurs qui ont suivi. Énergie de bruit non désirée quantique dissipe sous forme de chaleur dans le Quantum Purificateur plutôt que émergeant comme une couche de résidus de contamination sur les informations audio / vidéo.
Les avantages de ce processus se étendent au-delà de la longueur physique de Quantum Purificateur. Comme les électrons vitesse à travers l'épurateur, un effet de "sillage" est formée qui facilite la circulation du courant dans les conducteurs environnants du système de lecture. Présentation de Bybee Quantum purification dans le chemin de l'électron réduit le bruit quantique et augmente la vitesse du signal, résultant en une amélioration de la performance au-delà de ce qui est réalisable par un câble seul, ne importe comment bien conçu.
NOUVEAU - Crystal Technology (produits de la série Crystal)
Les atomes sont les blocs de construction de base de la matière ordinaire. Les atomes peuvent se unir pour former des molécules, qui à son tour former la plupart des objets qui vous entourent.
Les atomes sont constitués de particules appelées protons, électrons et des neutrons. Les protons ont une charge électrique positive, les électrons ont une charge électrique négative et neutrons portent pas de charge électrique du tout. Les protons et les neutrons se regroupent dans la partie centrale de l'atome, appelé noyau, et de l'orbite 'électrons le noyau.
Les atomes de carbone sont présents dans tous les êtres vivants, et dans les airs. Près de 99% des atomes de carbone sont des atomes C12, tandis que moins de 2% des atomes restants sont C13.
Bybee Technologies a développé un produit qui est excité par un champ d'énergie entourant. Une fois sous tension, notre produit résonne à la même fréquence que l'atome C13. Par conséquent, ce qui crée un champ magnétique de l'effet de la force. Dans ce champ magnétique, la polarité de tous les électrons et les protons sont modifiés, ce qui affecte leur oscillation en les rendant plus alignés entre eux. Cette réaction crée un affect qui fait le transfert ou le partage d'électrons entre les atomes plus de rationaliser et efficace; et les molécules d'air moins résistant.
Michel...
- MickeyCam
Et voilà un de ses magnifiques "purificateurs quantiques" à la modique somme de 360 $ l'un
et le texte qui va avec:
probablement juste une self avec quelques spires, ça fait cher la spire
lui doit les acheter au maxi 1 $ le sachet de dix
et il vend aussi un caillou sans alimentation aucune à 1200 $ :
Michel...
Grand GOLD Quantum Purificateur
Grandes Purificateurs Gold Quantum sont généralement utilisés dans les applications à courant alternatif (particulièrement recommandé pour l'électronique à l'état solide), et avec des transducteurs de haut-parleurs, en particulier modèles électrostatiques et métal conducteur. Spécialement blindé avec ERS furtif matériau de fibre de carbone.
Spécifications:
Longueur: 2 pouces
Diamètre: 1/2 pouce
Conduit: un pouce, calibre 14 en or 14K
De traitement de courant: 15 A
Tension:> 1 000 V
Résistance: 0,025 ohms
Prix: $ 360 chacun
Le Bybee - Quantum Amplificateur de signal par Bybee Technologies va transformer ne importe quel appareil audio ou vidéo à un niveau supérieur de performance avec Quantum technologie d'alignement de protons. Lorsqu'il est placé dans une pièce, il fonctionne également comme l'un des dispositifs de traitement de chambre les plus économiques et efficaces sur le marché.
Michel...
- MickeyCam
- coincarre
Juste une résistance, encore moins cher qu'une self
et 0,025 ohms, autant dire 0, donc ça ne sert à rien, et ça vaut encore moins 360 $
mais il y doit bien y avoir des gens qui en ont acheté, et depuis tout est transcendé
Michel...
Michel...
- MickeyCam
Patent-pending ?
roland_de_lassus - Modérateur Haute-Fidélité
Si on lit un peu le topic (lien sous l'image) on voit que John Curl est mouillé dans l'affaire... il aimerait bien qu'on ne lui pose pas trop de questions mais les vilains sceptiques ont réussi à en faire un topic de 150 pages et à l'accuser de publicité mensongère sans que celui-ci ne réussisse à démentir par aucune explication ou mesure.
J'ajoute que ces "purificateurs" sont présents dans certaines platines Audiocom dont on nous vante tant les tweaks sur les platines Oppo sur ce forum (et que par ailleurs le site Audiocom vend tout un tas de conneries dont on a déjà parlé) :
http://www.audiocominternational.com/94-tweaks
- coincarre
MickeyCam a écrit:Bonjour,
faut traductionizer, c'est plus marrant :Les "trucs" développé par Bybee contient des matériaux "semblables à des cristaux" qui sont activés par électromagnétisme et ont la capacité étonnante à affecter l'alignement de protons dans les atomes proximales spécifiques. Sur la base de ce modèle «old fashioned» de l'atome, un tel résultats de l'alignement dans le noyau ayant les propriétés d'une barre aimantée. Cette entraîne à son tour un chemin «plus facile» (plus stable) pour les CEM et donc une réduction des effets délétères de capacitive et la réactance inductive ainsi que le bruit moléculaire. Si les composants d'un noyau non alignés, les protons et les neutrons, le taux de désabonnement de produire en continu fluctuant pôles magnétiques, il est facile de concevoir que toute une gamme de noyaux pôles fixe fournira un chemin cohérent et prévisible pour le passage de particules chargées, ainsi que exercer une profonde influence sur le comportement des électrons dans la "orbite" du noyau. Ou quelque chose comme ça. Jack Bybee a pris soin de souligner que sa description, sur lequel se fonde cette spéculation, n'était qu'un hypothèse; ce que je ai écrit est plusieurs fois retirés de cela.
Michel...
Bon, alors il est temps de sortir la phrase magique, qui coupera court à toute discussion ioiseuse: "Tant que vous n'avez pas essayé, vous ne pouvez rien en dire"
- Robert64
- Contributeur HCFR
non c'est tant que vous n'avez pas écouté
Et encore faut il un système suffisamment résolvant et des oreilles bien entrainé pour faire la différence
autrement dit si tu n'entends rien pose toi les bonnes questions
- Iorn
- Inscription Forum: 28 Juin 2014 20:07
Et quand on connaît le temps de rodage d'un câble ou de tout composant électronique pour qu'il s'ouvre complètement et libère tout son potentiel, je ne suis pas sûr qu'une seule écoute puisse suffire. Il faut de longs mois et là la différence avec l'écoute faîte 2 ou 3 mois avant devient évidente
- coincarre
Iorn a écrit:...
Voilà. C'était la phrase manquante !
- Robert64
- Contributeur HCFR
cet appareil révolutionnaire révèle tout son potentiel à la fin de son rodage, juste après la date limite de reprise si non satisfait !
Michel...
Michel...
- MickeyCam
