j'ai branché un musical fidelity M6 500i sur mes PL300, il y a deux jours. Le résultat est interessant car il révèle le potentiel très élevé des PL300.
Cet intégré peut permettre de constituer un système très performant sans laisser deux reins et un oeuil
Les caractéristiques de l'ampli
Power 500 Watts per channel into 8 Ohms (27dBW)
Maximum output voltage 64 Volts RMS, 20Hz to 20 kHz; onset of clipping (179 Volts peak-to-peak)
Maximum peak output current 100 Amps
Damping factor >250 Output devices 6 pairs per channel
Line input
THD+N <0.01% typical, 20Hz to 20 kHz
Signal / noise ratio >100dB ‘A’-weighted
Input impedance 38k Ohms
Frequency response +0, –0.1dB, 10Hz to 20 kHz
Connections
Line level inputs 1 pair line level XLR (balanced) connectors 4 pairs line level RCA connectors
Line level outputs 1 pair line level RCA connectors, constant level TAPE outputs 1 pair line level RCA connectors, preamp outputs for e.g. biamping
Speaker outputs 2 pairs heavy duty 4mm banana plug/binding posts per channel
Power requirement
Mains voltages 115/230VAC 50/60Hz (factory pre-set) 100VAC 50/60Hz (alternative)
Consumption 0.25 Watts standby (Orange LED lit)
150 Watts on, idle (Blue LED lit, no signal)
2000 Watts maximum (Blue LED lit, full power output)
Weight
Unit only 28 kg
