Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: cholley, dabass, Fledermaus, MickeyCam, reservoirpulp, Symphone et 457 invités
[CR] FLYING MOLE Digital Power Amplifier DAD-M100pro HT
Message » 24 Aoû 2006 21:45
Trouvé sur http://www.audioasylum.com/audio/tweaks/messages/124606.html, plusieurs "tweaks" ou "mods" du DADM100 (notamment le bypass du controle de volume).
Attention au résultat quand même, cela dépendra des goûts et des tweeters qu'il y a derrière.
AudioAsylum.com a écrit:First, some background. I have the Flying Mole DAD-M100proHT digital amps, which sound pretty good right out of the box, but since I never leave well enough alone, I soon felt the need to tweak. In order, I changed the binding posts from the crap stock ones to the Premium 5-way gold-plated ones from Dayton, changed the RCA jack to the premium gold-plated from Dayton, bypassed the volume pot so that the input signal goes directly into the board, and replaced the input coupling cap with a Black Gate 10uF, 50V N-type. Then I decided to go to work on the power supply, so I replaced the stock D3SBA60 rectifier bridge with an IXYS 600V, 22A HyperFRED bridge, and finally, replaced the stock Si switching diodes with 600V, 4 A Cree SiC Schottkys.
The Results:
Bypassing the volume pot made a big difference in the clarity and transparency - not surprising since it is a poor quality pot that doesn't belong in a decent amp.
The Black Gate had a more minor effect - I could hear a little more clarity in the upper treble region, but it was much more subtle than the change from the volume pot removal.
The binding posts and RCA jack made no appreciable difference in the sound, but sure made it easier to hook up, and they look a lot nicer than the stock ones.
The IXYS HyperFRED replaced the stock Shindengen D3SBA60 bridge (D1 on the board) and definitely brought out more details, probably due to a lower noise background - the modded Mole seemed less rolled off at the top than the stock version, and cymbals had more shimmer. The install is a little complicated, since the pinouts are different between the stock and the IXYS: Pin 1 goes in slot 1, pin 2 in slot 4, pin 4 in slot 3 and pin 5 in slot 2. Pin 3 isn't used. I ended up cutting off pins 2, 3 and 5, and soldering hookup wire to pins 2 and 5 since the leads would have had to be twisted so much they would probably break (in fact I did break one on the first try).
The Cree SiC Schottkys are much easier to install, as they fit right into the eight board slots from the original 4 switching diodes (D2-D5), and they make a VERY noticable difference in the sound. The modded Mole had a much crisper, more detailed sound than the stock, with more emphasis on the upper mid and treble regions, where the stock is a little rolled off. I like the new sound a lot, but I prefer more detail - those who want a warmer, fuzzier sound most likely won't like it. Snare drums have more impact and brushes sound almost like they do live - I'm impressed.
All that said, the sound of the modded Moles is definitely more forward in the treble than it was previously. I like it, but others may not. When I get 4 more Moles to complete my 6.1 system, I will definitley mod them as well.
fgero
Inscription Forum: 23 Oct 2004 23:44
Message » 01 Sep 2006 9:45
salut
je vais sûrement en commander .je l'ai ai trouve en France a 780 euro la paire
si vous voulait l'adresse je vous la donne en mp sans problème
lotofoof46
Inscription Forum: 14 Nov 2005 12:13
Message » 01 Sep 2006 10:05
Oui je veux bien l'adresse stp
Merci ...
stloup
Inscription Forum: 12 Sep 2002 12:00
Message » 01 Sep 2006 11:07
lotofoof46 a écrit:salut
Hello,
oui, peux tu me communiquer cette adresse, stp. :)
herve29s
Inscription Forum: 15 Fév 2005 13:25
Message » 01 Sep 2006 13:38
dans le magazine haute fidélité il y a un article sur les flying mole.je n'ai pas le magazine j'ai juste vue cela:
http://www.journaux.fr/revue.php?id=100248
lotofoof46
Message » 01 Sep 2006 15:44
dans haute fidelite l'article est sur le cas 3
lotofoof46
Message » 01 Sep 2006 17:18
Oui moi aussi je veux bien l'adresse !... :D
Je sens que lotofoot va passer son temps à envoyer des mp... :wink:
Hobby One
Inscription Forum: 18 Mar 2003 22:41
Message » 01 Sep 2006 20:12
salut à tous
je viens d'acquerir un CA S3 (merci vanden!) :D
"faire autant de musique" dans un aussi petite boite relève de la sorcellerie
maintenant c'est sûr, les japonais ont vendu leurs âmes au diable. :evil:
Pour les blocs, à ce prix là, Hervé tu peux foncer et gare au coup de pied aux fesses.
noel briand
Inscription Forum: 11 Mar 2006 15:14
Message » 02 Sep 2006 12:08
sur quelle matériel a tu associe le cas3
lotofoof46
Message » 02 Sep 2006 13:44
bonjour
lotofoot reponse par MP.
noel briand
Message » 02 Sep 2006 14:17
noel briand a écrit:bonjour
Ah bon ? Même ça, ça ne se dit qu'en coulisse :o A quoi sert le forum alors ? :-?
Hobby One
Message » 02 Sep 2006 14:24
ma config est hautement confidentielle
boston CR 75
lecteurDVD Samsung 950
c'est dire................:D
c'était uniquement pour ne pas polluer le post
désolé si j'ai "fauté" :(
noel briand
Message » 02 Sep 2006 14:38
je viens de recevoir mes DADM100 (5-6 jours après la commande).
Le prix total fut :
630 Euros la paire de DAD-M100 port inclus
126 Euros de TVA (19.6%)
13 Euros de droits de douane
12 Euros de "frais de dossier)
Total : 781 Euros
Il étaient en parfait état, bien emballés.
Jes ai connectés, branchés au secteur, allumés et je suis parti un quart d'heure faire autre chose, sans mettre de musique.
A mon retour, mauvaise surprise :evil: :evil: :evil: :
un des deux blocs avait ses LEDs éteintes (alors que le bouton de facade était toujours à 1), comme s'il était débranché. Aucun son évidemment. J'essaie avec un autre cable secteur, une autre prise, rien. Il ne s'allume jamais.
L'autre bloc fonctionne bien, je l'ai laissé allumé plusieures heures.
Je ne sais pas ce qui a pu se passer, mais il s'agit d'un défaut manifeste.
Je viens d'envoyer un mail à l'expéditeur (et fabriquant) flyingmole.co.jp, je ne sais pas comment le problème va pouvoir être traité.
EN attendant, je n'ai pas de musique.
:roll: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil:
fgero
Message » 02 Sep 2006 14:48
Mince! :cry: :(
J'espère que ça va s'arranger!
Cdlt :wink:
dub
Message » 02 Sep 2006 15:25
quelqu'un connait ce distributeur en FRANCE ??
papaB2
Inscription Forum: 09 Avr 2006 22:48
