Salut à vous tous détenteurs de Cayin CDT-17A!!! Place au tweakage...
Ma Cayin CDT-17A d'origine:
CAYIN CDT-17A DE TEIKI ARII OPTIMISÉE PAR ANDRÉ DEVILLERS:
- MODE I (full OPA627BP, 4 x Condos MUNDORF 3.3uF 1200VDC SILVER OIL en XLR, ALIMENTATION CRC, MICA argentés NOS):
- MODE ULTIMA (MOD I + AOP discrets, Super Clock, Low ESR):
CAYIN CDT-17A RCA Full-PCM de Trencito en configuration 6 x Burson Single Discret OPA avec la Burson Clock:
CAYIN CDT-17A RCA Full-PCM de Zert en configuration 6 x Burson Single Discret OPA avec la Burson Clock:
Compte-rendus indépendants sur les E88CC/E188CC/7308/6922 compatibles avec la Cayin CDT-17A:
viewtopic.php?p=169884306#169884306" onclick="window.open(this.href);return false;
caractéristiques de la Cayin CDT-17A:
- uses American BB Corporation newest promoted 24bit/192kHz electric current output DAC PCM1792 carries on the D/A transformation.
- the first section true entire balance design CD broadcast machine, namely uses 2 piece of PCM1792 chip alone signal processes for two sound tracks distinctions.
- the complete vacuum tube outputs, the balance and the non- balance audio frequency output circuits uses Russia produces the 6922EH vacuum tube.
- the complete digital signal output, includes the optical fiber outputs, coaxial outputs, the balance (AES/EBU) outputs.
- lowly passes the filter circuit uses the American BB Corporation sound special-purpose transports puts OPA604.
- uses PHILIPS the CD7II numeral servosystem.
- Analog and the digital circuit separately uses the independent power transformer and the rectification constant voltage system supplies power.
- the use specially lowly leaks the magnetism, the highly effective rate ring-like power transformer for this machine development.
- the VFD lattice display monitor, the aluminum and the stainless steel combination kneading board, the outward appearance modelling luxurious is natural, is advantageous for matches with the different brand sound equipment.
- uses the 2mm steel plate purifies the engine case, the rigidity is good, machine the core uses entire seal dustproof structure processing.
characteristics:
* Output level: 2.3v±0.5dB
* Frequency response: 20Hz ~ 20kHz±0.5dB
* The distortion adds the noise: <-70dB
* Signal to noise ratio: 92dB
* Dynamirange: 120dB
* Crosstalk (fundamental wave 1kHz): -100dB
* Digital output: Conforms to the IEC958 standard
* The volume (long * width * high): 40mm×390mm×130mm
* Weight: 16kg
* Power consumption: 40W
APPLICATION INFORMATION of PCM1792 : (EXTRAIT du Data Sheet du PCM1792)
- APPLICATION CIRCUIT
The design of the application circuit is very important in order to actually realize the high S/N ratio of which the PCM1792 is capable. This is because noise and distortion that are generated in an application circuit are not negligible. In the circuit of Figure 36, the output level is 2 V rms and 127 dB S/N is achieved. The circuit of Figure 37 can realize the highest performance. In this case the output level is set to 4.5 V rms and 129dB S/N is achieved (stereo mode). In monaural mode, if the output of the L-channel and R-channel is used as a balanced output, 132 dB S/N is achieved (see Figure 39). Figure 38 shows a circuit for the DSD mode, which is a 4th-order LPF in order to reduce the out-of-band noise.
- I/V Section
The current of the PCM1792 on each of the output pins (IOUTL+, IOUTL–, IOUTR+, IOUTR–) is 7.8 mA p-p at 0 dB (full scale). The voltage output level of the I/V converter (Vi) is given by following equation: Vi = 7.8 mA p?p × Rf (Rf : feedback resistance of I/V converter) An NE5534 op amp is recommended for the I/V circuit to obtain the specified performance. Dynamic performance such as the gain bandwidth, settling time, and slew rate of the op amp affects the audio dynamic performance of the I/V section.
- Differential Section
The PCM1792 voltage outputs are followed by differential amplifier stages, which sum the differential signals for each channel, creating a single-ended I/V op-amp output. In addition, the differential amplifiers provide a low-pass filter function. The op amp recommended for the IV circuit is the NE5534, and the op amp recommended for the differential circuit is the Linear Technology LT1028, because its input noise is low.
liste des intéressés:
flom
momois
Gilles92
teiki arii.
liste des Op Amps candidats au remplacement des OPA604AP - Filter and RCA Op Amps -:
- monochips - échange standard -:
- Burson discret single OPA sûre
- OPA627 AP & BP sûre
- NE5534 sûre
- OPA227 sûre
- OPA134 sûre
- AD843 sûre
- AD845 sûre
- AD847 sûre
- LM6171 presque sûre
- AD797 presque sûre
- AD844 presque sûre
- OPA637 rejetée
- OPA228 rejetée
- dual chips nécessitant un "shunt" de l'une des deux - cf liens ci-dessous -:
- AD826/AD827 presque sûre
- OP275 sûre
- mono chips nécessitant un adaptateur SOIC8/DIP8 - cf liens ci-dessous -:
- AD825 sûre
- AD8610 sûre
- AD8065 presque sûre
- THS4631 presque sûre
- THS4031 presque sûre
Adaptateur d'une monochip SOIC8 pour faire une monochip DIP8 - original OPA604AP -, intéressant le RCA Op Amp - en position 1 - et les Filter Op Amps - en position 2 & 3 du schema B définitif de 00940 -
http://www.cimarrontechnology.com/index ... &ProdID=12" onclick="window.open(this.href);return false;
http://www.soundlabsgroup.com.au/brownd ... apters.htm" onclick="window.open(this.href);return false;
liste des Op Amps candidats au remplacement des dualchips AD827/NE5532 - I/V conversion Op Amps under red original heatsink -:
- NE5532 sûre
- OPA2134AP sûre
- AD826 sûre
- AD823 sûre
- AD827 sûre
- LM6172 sûre
- LM4562NA sûre
- Burson discret Dual OPA presque sûre
- Double OPA627 sur adaptateur DIP8 presque sûr
- THS4032 presque sûr, moyennant un adaptateur SOIC8/DIP8
- OPA2111 presque sûre
- AD828 presque sûr,
- AD8039 presque sûr, moyennant un adaptateur SOIC8/DIP8
- AD8066 presque sûr, moyennant un adaptateur SOIC8/DIP8
- AD8620 presque sûr, moyennant un adaptateur SOIC8/DIP8
- OPA2227 presque sûr, DIP8 natif
- EL2244 presque sûr, moyennant un adaptateur SOIC8/DIP8
- THS4631 presque sûr, moyennant un adaptateur DOUBLESOIC8/DIP8
Adaptateurs intéressants les I/V converter dualchips - original AD827/NE5532 - under red heatsink en position 4 & 5 du schéma B définitif de 00940:
- Adaptateur de 2 monochips SOIC8 pour faire une dualchip DIP8:
http://www.cimarrontechnology.com/index ... &ProdID=24" onclick="window.open(this.href);return false;
- Adaptateur d'une dualchip SOIC8 pour faire une dualchip DIP8:
http://www.cimarrontechnology.com/index ... &ProdID=18" onclick="window.open(this.href);return false;
- Adaptateur de 2 monochips DIP8 pour faire une dualchip DIP8:
http://www.cimarrontechnology.com/index ... D&ProdID=9" onclick="window.open(this.href);return false;
Schema et numérotation A selon flom de la Cayin CDT-17A:
Schema et numérotation B selon 00940 de la Cayin CDT-17A:
- monochip RCA Op Amp n°1: désymétrisation de XLR vers RCA - donc absent par la sortie XLR -.
- monochips Filter Op Amps n°2 et n°3: pour le filtrage des pôles + et -.
- dualchips I/V conversion Op Amps n°4 et n°5: pour la conversion I/V.
PCB de la Cayin CDT-17A:
viewtopic.php?p=168846726#168846726" onclick="window.open(this.href);return false;
Premier tweak de flom avec changement des OAP604AP par un système hybride 2XOPA134-4xOPA627 selon le Schema et numérotation A:
viewtopic.php?p=168737344#168737344" onclick="window.open(this.href);return false;
Première proposition de tweakage des condensateurs de sortie - PPMFX, PPFX-S -:
viewtopic.php?p=168737938#168737938" onclick="window.open(this.href);return false;
Tweak de flom avec changement des OAP604AP pour du "full"-OPA627 selon son schema:
viewtopic.php?p=168742897#168742897" onclick="window.open(this.href);return false;
Schema de Momois sur la façon de shunter la deuxième puce des dualchip:
viewtopic.php?p=168743420#168743420" onclick="window.open(this.href);return false;
Premier tweak de momois avec changement des OAP604AP par le système hybride 2XOPA134-4xOPA627 selon le schema A de flom:
viewtopic.php?p=168743817#168743817" onclick="window.open(this.href);return false;
Deuxième tweak de momois avec changement des OAP604AP par le système hybride 2XOPA627-4xOPA604 selon le schema A de flom:
viewtopic.php?p=168746011#168746011" onclick="window.open(this.href);return false;
Impressions comparatives entre flom et momois sur l'OPA627:
viewtopic.php?p=168746858#168746858" onclick="window.open(this.href);return false;
Adaptation et conversion d'un Op Amps SOIC8 en DIP8 en remplacement des OPA604AP/PDIP:
viewtopic.php?t=29777877&postdays=0&postorder=asc&start=150" onclick="window.open(this.href);return false;
Première mise en place - abandonnée - du schema B selon 00940 de la cayin CDT-17A:
viewtopic.php?p=168748700#168748700" onclick="window.open(this.href);return false;
Deuxième mise en place - retenue - du schema B selon 00940 de la cayin CDT-17A:
viewtopic.php?p=168749606#168749606" onclick="window.open(this.href);return false;
Découverte par momois des dualchips AD827 de conversion I/V sous les radiateurs rouges:
viewtopic.php?p=168750146#168750146" onclick="window.open(this.href);return false;
Troisième tweak de momois avec changement des OAP604AP par le système hybride 2XOPA275-4xOPA604 selon le schema A de flom:
viewtopic.php?p=168753680#168753680" onclick="window.open(this.href);return false;
Premier compte-rendu de teiki arii sur les 2XOPA627/OPA134/AOP227/OPA604 -4XOPA627 selon le schema A de flom:
viewtopic.php?p=168757208#168757208" onclick="window.open(this.href);return false;
Quatrième tweak de momois avec changement des OAP604AP par le système hybride 2XAD825-4XOPA275/4XOPA134 selon le schema A de flom:
viewtopic.php?p=168761620#168761620" onclick="window.open(this.href);return false;
Cinquième tweak de momois avec changement des OAP604AP par le système full 6XAD825 selon le schema A de flom:
viewtopic.php?p=168766352#168766352" onclick="window.open(this.href);return false;
transformation par momois d'un AD825-SOIC en AD825-DIP8 et d'un OP275dual en OP275monochip directement enfichables dans un socket OPA604:
viewtopic.php?p=168768622#168768622" onclick="window.open(this.href);return false;
démontage par momois de la carte PCB et vision du verso:
Premier tweakage des condos de sorties - mundorf m-cap 2,2uf 1200VDC - par flom:
viewtopic.php?p=168848043#168848043" onclick="window.open(this.href);return false;
tweak de Gilles92 avec changement des OAP604AP par le système full 6XAD843 et 2XAD843/4XOPA627 selon le schema A de flom:
viewtopic.php?p=168856385#168856385" onclick="window.open(this.href);return false;
Sixième tweak de momois avec changement des OAP604AP par le système 2XOPA134/4XAD843 selon le schema A de flom:
viewtopic.php?p=168869939#168869939" onclick="window.open(this.href);return false;
Septième tweak de momois avec changement des OAP604AP par le système 2XAD843/4XOPA627 selon le schema A de flom:
viewtopic.php?p=168914845#168914845" onclick="window.open(this.href);return false;
tweak de teiki avec changement des OAP604AP par le système 2XOPA627/4XAD843 selon le schema A de flom:
viewtopic.php?p=168960414#168960414" onclick="window.open(this.href);return false;
Comparaison entre OPA627BP & OPA627AP:
viewtopic.php?p=168999041#168999041" onclick="window.open(this.href);return false;
Comparaison en direct entre une Cayin CDT-17A non tweakée de Ranix (6922EH, Full OPA604AP, 2,3V RCA, WIMA 2,2uF 250VDC) à celle de flom (Amperex PQ 6922, Full OPA627AP, 2V RCA, Mundorf 2,2 uF 1200VDC)
viewtopic.php?p=169009324#169009324" onclick="window.open(this.href);return false;
Comparaison entre OPA627 et AD8620 par opensource:
viewtopic.php?p=169026150#169026150" onclick="window.open(this.href);return false;
Commentaires par momois des AD8610 en position 1 & 2 du schema de flom:
viewtopic.php?p=169072530#169072530" onclick="window.open(this.href);return false;
viewtopic.php?p=169091084#169091084" onclick="window.open(this.href);return false;
Comparaisons par momois entre Cyrus CD8, Musical Fidelity A5 et la Cayin CDT-17A sur Etalon/Prame Anthares de benz:
viewtopic.php?p=169146211#169146211" onclick="window.open(this.href);return false;
La melody CD17 sur la base d'une Cayin CDT-17A:
viewtopic.php?p=169170300#169170300" onclick="window.open(this.href);return false;
Cayin CDT-17A asymétrique (RCA) Exclusive; schema définitif:
viewtopic.php?p=169181507#169181507" onclick="window.open(this.href);return false;
De l'utilisation des AOP concernant le schema du PCM1792 par 00940:
viewtopic.php?p=169196541#169196541" onclick="window.open(this.href);return false;
Un petit CR de la Cayin CDT-17A -full OPA627BP- couplée à un ampli Vecteur I4.2:
viewtopic.php?p=169351151#169351151" onclick="window.open(this.href);return false;
Un petit CR de la Cayin CDT-17A de flom par boonjik:
viewtopic.php?p=169561272#169561272" onclick="window.open(this.href);return false;
Un petit résumé de l'utilisation des AOP et tubes de la Cayin CDT-17A:
viewtopic.php?p=169594925#169594925" onclick="window.open(this.href);return false;
Remplacement des AD827 par des NE5532 à l'étage de conversion I/V:
viewtopic.php?p=169616339#169616339" onclick="window.open(this.href);return false;
CAYIN CDT-17A DE TEIKI ARII OPTIMISÉE PAR ANDRÉ DEVILLERS MOD I:
viewtopic.php?p=169632052#169632052" onclick="window.open(this.href);return false;
Quelques explications indicatives sur l'optimisation ultime de la Cayin CDT-17A par André Devillers et siezien:
viewtopic.php?p=169819220#169819220" onclick="window.open(this.href);return false;
CAYIN CDT-17A DE TEIKI ARII OPTIMISÉE PAR ANDRÉ DEVILLERS MOD ULTIMA:
viewtopic.php?p=169842893#169842893" onclick="window.open(this.href);return false;
viewtopic.php?p=169902224#169902224" onclick="window.open(this.href);return false;
Un petit CR comparatif par boonjik et teiki arii portant sur les Cayin CDT-17 OAD/flom, Micromega Aria, Marantz SA-11, Accuphase DP-57, YBA Passion 400:
viewtopic.php?p=169946310#169946310" onclick="window.open(this.href);return false;
CAYIN CDT-17A DE SHANGAI_PLANET OPTIMISÉE:
viewtopic.php?p=170031376#170031376" onclick="window.open(this.href);return false;
et quelques explications:
viewtopic.php?p=170038121#170038121" onclick="window.open(this.href);return false;
viewtopic.php?p=170057309#170057309" onclick="window.open(this.href);return false;
Classement réalisé par boonjik portant sur nombre de CDP écoutées dont les Cayin CDT-17A de flom, d'origine et de teiki:
viewtopic.php?p=170417072#170417072" onclick="window.open(this.href);return false;
Liste des courses pour bien faire:
viewtopic.php?p=170174769#170174769" onclick="window.open(this.href);return false;
Un petit compte-rendu de Francis Ibre à propos des Burson Discret OPA:
viewtopic.php?p=170709670#170709670" onclick="window.open(this.href);return false;
Avis de Teiki sur l'Audio Buffer Burson XLR/RCA, les fusible AHP et la comparaison OPA627BP/Burson Discret AOP:
viewtopic.php?p=170454849#170454849" onclick="window.open(this.href);return false;
La solution Burson -à composants discrets- expliquée, pour brancher la Cayin CDT-17A sur un préampli Asymétrique -en RCA-:
viewtopic.php?p=170458294#170458294" onclick="window.open(this.href);return false;
Mise en place, photos à l'appui, de la Burson Clock expliquée par Trencito:
viewtopic.php?p=170520474#170520474" onclick="window.open(this.href);return false;
Premier CR par Trencito de la Cayin CDT-17A/RCA Full Burson Discret Single OPA & Burson clock:
viewtopic.php?p=170523039#170523039" onclick="window.open(this.href);return false;
Mise en place de la Burson Clock expliquée, des Burson Discret OPA en RCA Full PCM et du fusible doré AHP par flom:
viewtopic.php?p=170583762#170583762" onclick="window.open(this.href);return false;
[CR] de flom:
viewtopic.php?p=170605352#170605352" onclick="window.open(this.href);return false;
[CR] de Zert et Trencito concernant les fusibles Isoclean fonction de leur sens d'insertion :
viewtopic.php?p=170611106#170611106" onclick="window.open(this.href);return false;
[CR] de Zert après modification Full PCM Burson Single Discret OPA, Burson superclock, Condos Mundorf en RCA (à l'identique de flom) avec tubes Mullards E188CC:
viewtopic.php?p=170609507#170609507" onclick="window.open(this.href);return false;
Proposition de bypass des Burson Discret OPA par gOng, Djilbe et Francis Ibre:
viewtopic.php?p=170706219#170706219" onclick="window.open(this.href);return false;
viewtopic.php?p=170706994#170706994" onclick="window.open(this.href);return false;
[CR] de momois après modification Full PCM Burson Single Discret OPA, Burson superclock, Condos Mundorf en RCA (à l'identique de flom) avec tubes Mullards E188CC:
viewtopic.php?p=170709121#170709121" onclick="window.open(this.href);return false;
CAYIN CDT-17A RCA BURSON DE MOMOIS AVEC ALIMENTATION DÉDIÉE DE LA CLOCK:
viewtopic.php?p=170789183#170789183" onclick="window.open(this.href);return false;
CAYIN CDT-17A XLR FULL-FULL BURSON DE TEIKI ARII OPTIMISÉE PAR ANDRÉ DEVILLERS & SIEZIEN:
viewtopic.php?p=170779632#170779632" onclick="window.open(this.href);return false;
Une alternative aux Burson Discret OPA; le single LME49710NA et le Dual LM4562NA:
viewtopic.php?p=170783283#170783283" onclick="window.open(this.href);return false;
[CR] de nnay07 après modification par André Devillers en Burson Single Discret OPA, Burson superclock, Condos Mundorf avec tubes Mullards E188CC:
viewtopic.php?p=170955957#170955957" onclick="window.open(this.href);return false;
Cayin CDT-17A de nnay07 après modification par André Devillers en Burson Single Discret OPA, Burson superclock, Condos Mundorf Silver/Gold:
viewtopic.php?p=171016855#171016855" onclick="window.open(this.href);return false;
Tweakage des condos de sorties et CR - Duelund VSF Copper Foil - par zert:
viewtopic.php?p=171153403#171153403" onclick="window.open(this.href);return false;
viewtopic.php?p=171172333#171172333" onclick="window.open(this.href);return false;
Utilisation du "CD-Flop" et des PEEK HAL-O 9 par zert:
viewtopic.php?p=171232897#171232897" onclick="window.open(this.href);return false;
viewtopic.php?p=171264558#171264558" onclick="window.open(this.href);return false;
Cayin CDT-17A version définitive réalisée par AZP:
post177957745.html#p177957745
Images haute résolution:
Il suffit de cliquer sur l'image pour la voir apparaitre sur l'écran en haute résolution.
Quelques sites où se la procurer éventuellement:
viewtopic.php?p=170254784#170254784" onclick="window.open(this.href);return false;
http://cgi.audiogon.com/cgi-bin/fb.pl?u ... 17&1&1&1&1" onclick="window.open(this.href);return false;
Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 23 invités
Les Lecteurs CD & SACD
Tweakage de la Cayin CDT-17A diapason d'or 2005
- teiki arii
- Inscription Forum: 19 Aoû 2004 19:24
J'attends la mienne sous peu pourquoi pas ?
Il faut voir financièrement à combien ca reviendrait (à peu près), les améliorations techniques apportées et surtout ce que ca apportera réellement à l'écoute
Arnaud
Arnaud
- ARNO 31
- Inscription Forum: 25 Mar 2002 2:00
Il est sûr que si on le fait tous en même temps, on risque tous d'y perdre d'un seul coup... Mais franchement, ça ne m'inquiète pas quand je vois - mais pas entendu - ce qu'il a fait de la Jolida de iblieve...ARNO 31 a écrit:Salut,
- teiki arii
+1.
Je suis preneur d'info de monsieur FP. Ca fait potentiellement 3 !
- flom
- Inscription Forum: 22 Jan 2004 10:53
momois m'avit dit que les aop étaient des BB604, si c'est le cas, je vous conseille vivement de les remplacer par des 627 !
- bribou
- Inscription Forum: 21 Nov 2002 11:37
Merci du conseil bribou, on va en tenir compte. Je pense qu'il va falloir proposer différents types de tweakage fonction des moyens de chacun....bribou a écrit:momois m'avit dit que les aop étaient des BB604, si c'est le cas, je vous conseille vivement de les remplacer par des 627 !
Si d'autres bonnes âmes du forum DIY ont des idées, qu'ils nous le fassent savoir, nous sommes preneurs...
Pour les BB604 , c'est écrit à la première page. Qu'est-ce qu'apporte le remplacement par des BB627?
- teiki arii
Il y en a à vendre en 220V natif là pour ceux qui la recherchent:
http://cls.audiogon.com/cgi-bin/cls.pl? ... 1116369453
- teiki arii
teiki arii a écrit:Je pense qu'il va falloir proposer différents types de tweakage fonction des moyens de chacun....
ce qui serait interessant c est de proposer plusieurs niveaux de tweakage, je developpe :
Pack1 : Pack de base simple a realiser
- bitumage + blutack (amortissement interne le plus comlet possible, bien que le chassis soit deja pas mal realise...)
- changement des tubes (bon ok, c est du deja vu et on a une certaine experience sur ce qui passe le mieux sur cette platine
- changement AOP (ils sont sur support tulipe, donc pas besoin de souder quoi que ce soit
Pack 2 :
- Changement des condo de sortie par du HighEnd... a determiner (la il faudra souder...)
Pack 3 :
- changement des alimentations afin d acueillir des 288 (pareil, soudage necessaire...)
- voir si on ne peux pas ameliorer le reste de l alim pour des regulateurs plus performants et diodes a communtation rapide si c est pas deja le cas..........
Pack 4 :
super clock ???!!!
Bref, voila ce qui me parait realisable, mais a etudier plus precisement par un pro du DIY....
Tous ces changements ne sont pe etre pas necessaires, il faudra voir dans les entrailles de la bete ce qui est le plus judicieux
Je pense perso qu avec les pack1+2 on peut deja realiser un bon tweak...
- momois
- Inscription Forum: 25 Fév 2003 18:55
Et qui donne sa platine comme "cobaye" ???
Arnaud (qui n'a meme pas encore recu la sienne )
- ARNO 31
Moi, comme d'habitude...ARNO 31 a écrit:Et qui donne sa platine comme "cobaye" ???
Ca pourra permettre la comparaison avec une non tweakée...
- teiki arii
teiki arii a écrit:Moi, comme d'habitude...ARNO 31 a écrit:Et qui donne sa platine comme "cobaye" ???
En fonction du budget, ma platine est également "pilote"!
- flom
kesako "pilote"...comme drive tu veux dire?flom a écrit:teiki arii a écrit:Moi, comme d'habitude...ARNO 31 a écrit:Et qui donne sa platine comme "cobaye" ???
- teiki arii
A première vue pour le pontde diode, si je suis pas trop miro et que je l'ai bien vu , c'est un pont un peu batard moulé... ca va être difficile de le remplacer par des schottky ultra rapides....
Pour ce que je vois, sur le tweak, on voit bien des mundorf, seraient-ce des condos mis en sortie pour filtrer le continu ?
- beb
teiki arii a écrit: kesako "pilote"...comme drive tu veux dire?
Bein, "pilote" comme "projet pilote", c'est à dire "plus qu'une maquette/prototype" car opérationnel si tout se passe bien, et qui permettra (je l'espère) de démontrer/proposer des résultats qui serviront de comparaison sur la base d'objectifs spécifiés ... Après pilote, il y aura les suiveurs
- flom
oui?! allô la terre...beb a écrit:A première vue pour le pontde diode, si je suis pas trop miro et que je l'ai bien vu , c'est un pont un peu batard moulé... ca va être difficile de le remplacer par des schottky ultra rapides....
- teiki arii
